Go to solution Solved
Number on screen won’t go away
(Topic created on: 10-12-2017 05:31 AM)
Priscilla02
 I recently purchased this TV and finally have it up on the wall. But for some reason this number appeared and it won’t go away, could someone please advice?
nycangels
Reset the TV - unplug it from the wall while it is on (do not turn off using the power button).  Wait one minute, plug it back in and turn on if it doesn't turn on automatically, and it should be gone.
2 REPLIES 2
nycangels
Josh13
My tv doesn't show display I left it unplug overnight and plugged it back in this morning it turns on automatically with no display..what can I do..?
