No volume on firestick
(Topic created on: 02-02-2021 04:54 PM)
Lorraine
TV
Recently purchased UE50TU7100 tv, I have sky-Q connected through Bose sound system and a firestick. When I switch over to the firestick I have no volume. Any help would be appreciated
1 REPLY 1
AndrewL
TV
@Lorraine : Do you have the Firestick connected directly to the TV, or is connected to your Sky Q or Bose system? Have you tried connecting the Firestick to another HDMI input to see if the issue persists? Also, try heading into the Firestick settings > Display and Sounds > Audio > Dolby Digital Output, and disable Dolby Digital Plus if applicable to see if this helps. While you're here, check your other available audio settings to see if there's anything you can adjust that might resolve the issue.
