15-06-2022 12:20 AM in
STV player is no longer showing on my tv
When I search the apps so that I can download it again, it doesn’t even show as an available app
This is a Samsung model ue32f6200 software version 2127
Solved! Go to Solution.
17-06-2022 05:55 PM in
@AntS Thanks for confirming, that explains it.
@Maz6 Unfortunately not now compatible with your model but other options for viewing including external devices as explained in the article I posted earlier.
One Ui 5.1,Android 13 .
15-06-2022 03:09 PM - last edited 17-06-2022 06:01 PM
Hi @Maz6 you certainly have the latest firmware. Go to Settings -Support -Self Diagnosis > Reset Smart Hub.
If still issues possibility support has been withdrawn though previous information was that it was compatible with 2013 sets (which your model is), https://www.digitalspy.com/tech/a484525/stv-player-now-available-on-samsung-smart-tv/ Help guide here https://support.stv.tv/support/solutions/articles/2000007702-which-platforms-are-supported-by-stv-pl...
17-06-2022 04:30 PM - last edited 17-06-2022 04:32 PM
Cheers JAMES4578!
But, I've had it confirmed: it's no longer possible to support the latest requirements of the STV Player on 2011-2014 (D range to H range) models due to technical limitations, and so it's been removed.
17-06-2022 07:39 PM in
Thanks James 4578 Guess I’ll just have to do without on this telly
is it possible to download it to Firestick for example?
17-06-2022 08:07 PM in
Hi @Maz6 yes ,the app is available on a Firestick.
