31-01-2021 01:16 AM in
TVJust got our replacement samsung TV and have now realised there is no one connect box for this model.
As such I had a one connect in the old TV and that is the only cable (apart from power and LAN ) that is in the brick wall
I need to use all 4 HDMI inputs and i dont think ill be able to get them up the wall
Is there some way the oneconnect cable can be used and a splitter box of sorts mounted behind the TV so I can avoid running new cables
Actually always buy Samsung for the consistency of cabling and now they have gone off the OneConnect cable for some reason - frustrating!
Any ideas would be much appreciated as there really is not much space in the wall cavity
David
31-01-2021 01:38 AM in
TV
right
not available under Specs → More→ Accessory
31-01-2021 06:29 PM - last edited 31-01-2021 06:31 PM ) in
TVThe Q95T has the OneConnect box. I don't think you can use any sort of splitter.
