No hdr+ mode on settings and wont allow 4k on xbox one s
(Topic created on: 02-02-2020 07:56 PM)
Ckj119
Just bought a samsung UHD 7 series UE43RU7100K and the xbox wont allow 4k mode as it says the tv doesn't support it? And the is no HDR+ mode in the settings even tho the tv is said to be 4k. Anyone have any ideas?
2 REPLIES 2
CarlH
Hi @Ckj119. Just been looking at the specs of this TV and it supports 4K, HDR10+. You may need to tweak some settings on your Xbox One S for this, though I'm not sure if anything other than the Blu-ray films support 4K (you may need to contact Microsoft for clarification).
JAMES4578
Samsung Members Star ★★
Hi @Ckj119  as @CarlH  has indicated it is advisable  to check  settings on XBox One S
https://beta.support.xbox.com/help/hardware-network/display-sound/do-my-xbox-and-tv-support-4k
However the One S cannot display games  in native 4k but can  upscale games.   It does support 4k for streaming and   Blu Ray Discs.
The ambient.com/guides/xbox-one-4k-essential-guide
