05-11-2020 08:14 PM in
TVHello
I’ve just purchased a q95t 65 inch tv with the no gap tv wall mount.
However where I am placing my tv, I have a double plug socket on the wall (the plug socket is roughly where I want the height of the centre of the tv to be).
My question is, will there be a big enough gap behind the tv to allow for this plug socket?
Thanks in advance
Jonny
22-11-2020 12:49 PM in
TVI am also looking for a response to this issue. Literally about to purchase the 55 inch version of the tv and want to make sure it is going to fit flush to the wall. I also have a double socket . Another question I have is the dimensions of the one connect plug on the smallest end? I want to make sure it fits in the wall recess which is already plastered in the wall.
will keep an eye on the response.
12-04-2021 05:37 AM in
TVDid you ever get a response?
26-11-2021 09:49 PM in
TVHi all, I im in a similar position as above - about to purchase the 55 inch Frame but have a double socket behind it. Did anyone receive a response or has done this and can provide any feedback? Thanks
27-11-2021 01:55 AM in
TVI was in a similar position. The TV mounts flush with the wall. I could kind of get it to work by tilting the flange on the wall mount, but I ended up removing the sockets for it to hang as designed. Nobody knows I have the worlds worse patch job behind the TV but me. Well, and now you.
12-12-2021 05:07 PM in
TVHi, thanks for letting me know and glad you sorted yours. This info is really helpful. We will too have a terrible patch job behind the tv!! Cheers
