No bluetooth
(Topic created on: 21-02-2021 11:57 AM)
Guzun Ionel
Hi community! I recently bought a Samsung 2020 65 "TU7020 Smart TV! which would be the problem with bluetooth ? he can't find it at all
5 REPLIES 5
Pugs1957
SuperStar
It doesn't support Bluetooth.
AndrewL
@Guzun Ionel: Are you attempting to connect a Bluetooth speaker? If so, place the speaker in pairing mode and head to Settings > Sound > Sound Output > Bluetooth Speaker List, where it should be available for selection.
Pugs1957
SuperStar
Here's the spec Buy 43-75 Inch UHD 4K HDR Smart TV | TU7020 | Samsung UK
Surprisingly, there's no Bluetooth.
https://www.google.co.uk/amp/s/www.trustedreviews.com/reviews/samsung-ue50tu7020/amp
upsetbluetoother
Can Bluetooth be retro installed on tu 7020 65 inch
Dildar Hussain
You will need to buy a USB Transmitter which is likely to come with a 3.5 mini jack cable. However, this TV model does not have a port for the 3.5 mini jack cable, therefore, you will also need to buy an Digital Audio (Optical) adaptor. Stick one end of the cable to the USB Transmitter and the other into the Opyical adaptor. The adaptor will need to be connected to back of the TV, just underneath the USB port. It has a label that says "Digital Audio Out (Optical).
Both the USB transmitter and the optical adaptor should cost around £7 - £8 in total from eBay.
