Network connexion when using smartview
(Topic created on: 04-01-2021 08:14 AM)
marchorg
I'm using smartview on TV and smartphone. It does work when both are connected on WIFI. However, the TV can be connected on the Ethernet network (with cable). Why does smartview not work when TV is connected that way although on the same network as the smartphone?
1 REPLY 1
Shazzkid
Troubleshooter
It should work just the same. Perhaps on ethernet the TV is hidden from the rest of the network. The settings for this may be found in the TV menus, or in your Routers settings.
