Netflix and Videoland sound glitch on UE49NU7100
(Topic created on: 11-11-2018 06:40 PM)
LS91
Just bought my new UE49NU7100. and I have it connected to a marshall Woburn speaker via optical cable.
It works great watching tv and listening to Spotify. But when I start the Netflix or Videoland app the sound starts to glitch...
When I switch back to the internal speaker it is fine. The sound only glitches when I use the optical external speaker.
Link to the video I Made: https://youtu.be/Sfhfo9WRaHw
Please help
Thanks!
5 REPLIES 5
ChrisM
SuperStar
Hi @LS91.
Did you manage to sort this issue or are you still having the same problem?
LS91
Hi Chris,
The problem is still occuring. Even when I set the sound on the internal speakers, there is still somehow a signal to my speaker. And starts buzzing and glitching like in the video I sent. (Note: It only seems to occur with video apps like: Netflix, RTL XL, videoland, NPO start, and facebooktv. While apps like spotify and YouTube don't give problems at all. )
The optical cable gives a Nice red light so seems Just fine.
Best regards.
Janekfcb
Got the same With ru7400 and Marshall Woburn speaker. Nas somoen rewoltę the issue? Samsung can you Please help.
LS91
Hi!
Sorry I did nog mention the sollution here,
Go go settings -> sound -> expert settings -> and make sure the sound format is set to PCM and not Bitstream.
Janekfcb
Thank you, i was diggining in options wanted to add the same,
yes this is working :smiling-face: Marshall works only with stereo.
