Need help connecting sound bar to tv
(Topic created on: 17-11-2018 06:28 PM)
steven19831
I have a HW-H355 model sound bar and I can't connect it to my SAMSUNG QE55Q6FAMT 55" Smart 4K Ultra HD HDR QLED TV need help with this
3 REPLIES 3
mark8805
You need to connect the sound bar optical to your Tv box optical IE. Sky, Virgin, Talktalk not to the Tv optical then tell the Tv that you are connecting sound to optical Input/Output.
paul1277
Black Belt
Does the sound bar have a HDMI in?  If it does best to connect using the ARC HDMI from the TV to the sound bar. The reason is you can get Dolby Digital+ through HDMI,  but just Dolby digital through optical.
steven19831
No HDMI but does have usb and optical out says has bluetooth but no button on it for bluetooth so it can be found by tv so I'm a bit stumped
