need a new one connect cable
(Topic created on: 21-01-2021 03:24 PM)
johncronin66
Hi  All
I require a new one connect cable for my Samsung TV model UE65KS8000. Are all Samsung one connect cables compatible and therefore I should just buy one from an internet seller ?
Many thanks
John
1 REPLY 1
obitv
Pathfinder
the one connect box & cables for all the KS models are the same. the part you need is Bn91-17814c. Best to buy a new one as you can get more years out of it.
try your nearest Samsung authorised repair center. goto through samsung support page to locate one
