11-04-2021 10:12 AM in
TVHiya,
all the ads show two, three and four multi-image options for the mounts but I can't find how accomplish this. Any tips anyone?
Thanks.
Andy
Solved! Go to Solution.
14-04-2021 11:58 PM in
TVNo you can't do it from the tele itself Samsung sham advert. You can do it if your images are exactly in correct format from the smart things ap on your Samsung smartphone. Don't use high deff pictures though as the app strugles.
12-04-2021 10:37 PM in
TV13-04-2021 10:35 AM in
TVHi, the ads for the Frame show bevel-cut mounts two or three images at the same time when in art mode, as in the attached, but I can't find instructions how to do so?
thanks
Andy
13-04-2021 04:25 PM - last edited 13-04-2021 06:15 PM ) in
TV@Andyfo2: While in Art Mode, go to My Collection > Photos > Select a photo > Edit Matte. Are you able to select the Matte Layout from here?
15-04-2021 12:15 AM in
TVThanks
I had begun to suspect that it wasn't as simple, or as 'Smart', as the publicity suggested.
24-06-2022 09:55 AM in
TVStrange that the system does not let me like your coment, maybe the truth hurts! Yes you must use the app to do it and the size of pictures must be correct.
