MU6100 - Plastic Base hair cracks
(Topic created on: 12-05-2021 03:02 PM)
Fede_777
Today I noticed a couple of hair size cracks on the plastic base of my MU6100, has anyone else seen this?
9 REPLIES 9
antikythera
Black Belt
No, same shape base on my TV and it's fine. Where the crack is shouldn't be under stress so that is very odd
Fede_777
Asked a couple of friends and at least one has the same problem but way more noticeable
antikythera
Black Belt
The ABS plastic is a fairly thin cover for a metal framework inside the stand, what size TV is it? Might be a factor as my old 5 series is only 32" so not exactly putting much force through the stand. Also, are the rubber feet okay, not uneven or visible out of place?
Fede_777
Both, mine and my friend are 50 inch, nothing seems out of place.
antikythera
Black Belt
I have it on a glass riser stand on top of an old TV unit as I needed a couple of additional shelves for devices
antikythera
Black Belt
50" pushing down on it? Then yes the stand is most likely overloaded, the plastic stress crack shouldn't happen though
Fede_777
It's the one that came in the box, if it's happening I think it's a design flaw.
PRO_MAN
OH NO ITS TOTALY BROKEN!!! 😴 don't worry its little
antikythera
Black Belt
Yes unfortunately, the stand is not robust enough for a 50" screen putting cantilever force on it. Have you got a safety tether on the back of the TV to your entertainment unit? If not it would be wise to install one before the stand fails completely
