19-12-2020 08:33 PM
Samsung hidden menu results in top bar showing MODE : FAILURE
any suggestion what has failed, how to fix?
20-12-2020 04:16 PM
Hey @Mg9302, can you send a picture of the screen of the TV showing this error message? Also, what is the model number of the TV? You can find this on the back label. Please also make sure that the TV is running on the latest software version: Menu > Settings > Support > Software update > Update now, unplug the TV, plug it back in again and turn it on.
09-09-2022 11:13 PM
I have the same issue. What is wrong?
11-01-2024 08:09 PM
I also get Mode Failure on the secret menu Does the problem lie with the one connect box? I can`t get Terrestrial or Freesat to work. They worked previously.
