Missing Freeview channel
(Topic created on: 24-06-2017 06:58 PM)
Sueswimmer
I have two Samsung Smart TVs.  Freeview channel 45 (Film4+1) is in the channel list on UE32J5500 but LT24D390SW/XU tells me the channel does not exist!  I've done two new scans with the same result - how do I add Freeview channel 45 to this TV?
1 REPLY 1
simon_w
Pioneer
Hi Sue
I have exactly the same issue between my 7000 series Smart TV and a much older set.
Unfortunately Film4+1 on Ch45 is only available on sets equipped with Freeview HD - this from Ch4's website:
Due to a change in the way that Film4+1 is broadcast on Freeview, unless you have a Freeview HD TV or set top box you will no longer be able to receive the Film4+1 service post Thursday 20 November. You will still be able to receive Film4 as normal on channel 15.
Unfortunately, we are aware that some viewers have already lost the +1 service, if you have an HD box, please try a retune, if you don't have Freeview HD, then I am afraid that the +1 service is no longer available.
