28-12-2016 02:20 PM
Solved! Go to Solution.
04-01-2017 10:45 AM
If the app has downloaded correctly to your laptop, you do not have to download anything to your TV. When you first use it a code number will appear on the TV, that you then
enter on your laptop. If this doesn't happen, it could be due to the fact that your are watching for instance, Sky on your TV via HDMI. The app will only work if your TV is on "TV mode" i,e freeview, and not HDMI.
Note: it can take up to a couple of minutes to establish the connection.
29-12-2016 02:56 PM
Hi Chrissiedp,
Thanks for posting and welcome to the Community! Are you needing help or just wanting a chat?
EmmaS
29-12-2016 06:52 PM
Hi EmmaS,
I need help to figure out how to mirror my Samsung smart tv to my laptop. Tried allsorts but have run out of ideas.
Many thanks. Regards - Chrissie
29-12-2016 07:38 PM
Which model TV do you have?
Also, what have you already tried?
29-12-2016 07:44 PM
Hi,
The model is UE40K6300AKXXU
I`ve tried downloading apps. When I try to download Smart View it`s telling me that "this appis not compatible with my device. (Smart tv?????? )
29-12-2016 08:00 PM
Thanks for that,
Is the Error Message coming up on your Laptop or your TV?
Are you using a Samsung Laptop?
For more information check out page 15 of the manual: http://downloadcenter.samsung.com/content/UM/201612/20161216094622174/ENG-HMFDVBEUK-1.0.8.pdf
29-12-2016 08:04 PM
04-01-2017 10:45 AM
