10-12-2022 11:03 AM in
TVTrying to install the projector to fit into 120 inches fixed screen. According to manual the horizontal distance should be 16.3 inches and vertical 17.3 inches. My question is from where this distance shall be measured? Like for vertical distance, is it from the base or from the top of the projector and for horizontal, is it from the lens or from the edge of the projector to the wall.
