07-02-2021 09:41 AM in
My father Has the QE55Q95T QLED tv and after connecting some beats Bluetooth headphone to it I noticed the volume is very low. If I connect the headphones to my phone then the volume will go much higher so I’m assuming there is some limitation/setting with the TV I’ve not set up. I’ve seen some general comments about needing to use a Samsung headset but wanted to see if anyone has had any luck getting a higher volume?
