01-10-2017 07:50 PM in
TVJust bought uhd ue43mu6100 I also own a Panasonic sub and sound bar if I connect via hdmi arc the system works fine until I select a hd Chanel then the sound disappears after about 20 seconds it does eventually come back but can be intermittent, I have since tried removing the hdmi and using optical connection but same happens
any ideas
