28-02-2020 01:05 PM
Hi,
Like any others I am having problems on lip sync. My set up is a Samsung QLED Q90, Sky Q and Bowers and Wilkins Pamorama 2 soundbar.
If I connect sky q via HDMI to the TV One connect box (TV) , and HMDI arc from the One connect box to the HDMI ARC on the soundbar,. picture is fantastic but bad lip sync experienced, especially on live HD and UHD channels.
The audio time delay on all three components is set to zero but it needs a negative setting, not a positive one, there is not a negative delay available on any.
If I change the config and pass the Sky Q signal through the soundbar, so HDMI to soundbar, ARC to TV, lip sync is sorted BUT Sky Q does not recognise that a UHD TV is connected and so I cant set picture output to UHD - aarrrgh!
Any ideas?
Is it the TV, do I need to change my soundbar or buy and go through an AV receiver (sounds overkill witha soundbarwhich has a negative delay function for video/audio?
Pretty awful when you purchase top of the range TV, decent soundbar and latest cable.
Thnaks in advance,
David
27-03-2020 09:20 PM
Yes - exactly the same problems.
if you set your Sky Q HDMI sound output to Normal instead of Dolby, I think the lip sync will be ok, and with a sound bar, that might work for you.
For me, I use an AVR, so I lose 5.1 surround doing this. I think it’s unacceptable that Samsung sells kit that is incapable of taking Dolby sound through its OneConnect and out through either ARC or Optical to an AVR without maintaining sync.
30-11-2020 06:24 PM
Hi David,
Did you overcome your issue? If so how did you do it, as I am currently very frustrated with the lip sync issue.
Also feel let down by Samsung as twice they've promised to call me back but have not!
Thanks
02-12-2020 09:47 AM
02-12-2020 10:00 AM
Thanks - I'd be interested to know what it is about Sky's Audio & Video signals that lead to the lip-sync issues they come in to the Samsung TV in sync, but get out of sync if the Audio gets directed to a sound system. I also (have to) take Sky's optical output to by sound system, but have to manually switch that sound system to use that input when necessary. This is disappointingly inconvenient given the cost of all the equipment.
02-12-2020 03:56 PM
It’s not just sky. I believe it must be tv as I have a firestick plugged in to a q90t and it’s all out of sync. Only way I fixed was to go into menu and go to pass through as I have a receiver that it’s plugged into. This fixes the audio sync issue but I get a random audio cut out every 45 mins which lasts 1 second each time.
Any ideas?
also anyone with a receiver, try audio pass through as this may help with your issue.
03-12-2020 08:35 AM
It's hard to believe that it's not 'big news' that Samsung can't engineer audio & video signals to stay in sync. No reviews address it.
Yes, pass-through would work, but then I'm back to my Receiver being the 'switcher' for my external sources (Sky, Blu-ray and Apple TV), and the TV being the switcher for the TV's apps (Netflix, Prime, YouTube, etc.). This defeats the purpose of buying the TV to be a single point of control for all sources with a single remote.
