Light bleeding
(Topic created on: 30-09-2021 02:31 AM)
Dibsta
Light Bleed will this be fixed under warranty
2 REPLIES 2
ChelseaH
Voyager
Hi @Dibsta
I would recommend speaking to your nearest Samsung Support Centre regarding this, as an engineer would be able to determine whether this is covered in warranty or not! You can find your nearest here > https://www.samsung.com/uk/support/service-centre/
antikythera
Black Belt
that's not light bleed, it's a completely messed up backlight. light bleed is usually around the edges of a laptop or TV where the screen meets the bezel and a bit of light is visible in the gap
