Go to solution Solved
LE26R41BD X/ZEU doesn't store channels
(Topic created on: 03-08-2017 09:52 AM)
banjo
I updated my channel list yesterday as the Freeview channels had changed.  Evertime I turn the TV on it displays No Signal.  This is because the channel list is empty.  If I rescan, it finds all the channels and works until I turn off and I am then back to No Signal.  I have tried a reset which made no difference.
banjo
I have solved this by changing the firmware back to an older version.
1 REPLY 1
banjo
