Go to solution Solved
Language setting on smart TV
(Topic created on: 23-09-2022 01:44 PM)
BrianA65
How can I change the language on my Samsung N4300 24 Inch Full HD Smart TV. The language is set to English in the settings but the apps are showing German language channels?
JAMES4578
Samsung Members Star ★★
Hi @BrianA65 Try a Factory Reset and change the region as suspect Uk not selected.
1 REPLY 1
JAMES4578
