Go to solution Solved
Ks9000 and openbox v8s
(Topic created on: 21-01-2017 08:17 AM)
Jjbur69
 Hi I am looking for some help connecting an open box 8vs to my samsung ks9000.when connected I have no audio I know the hdmi lead is OK and the audio is fine from the box when connectedto an older samsung tv all other boxes are okay  connected to the tv I have changed all audio settings on the box and tv to no avail. The only thing different is when the open box is connected it has the connection name hdmi/dvi. Any advice would be really appreciated as I am completely stumped.
3 REPLIES 3
AntS
Hi Jjbur69! :smileyhappy:
Are you able to check if there's any software update available for the Openbox?
AntS
