Go to solution Solved
KS8000 picture quality
(Topic created on: 24-06-2017 01:27 AM)
Vinnieac
TV
I have recently purchased this TV and have an issue with the picture. Frequently the image seems to buffer or stutter, especially when a person is moving etc.  It is not a constant blur or judder but happens every few minutes, more on certain channels. I have tried all settings including the motion ones but this has no effect. The only way I can watch TV is by selecting the game mode. However this then disables all the settings I would like to use, and the reason I bought this set. The latest firmware is installed. The issue occurs either through Sky HD or terrestial. It seems to be the processor struggles to keep a constant image quality. Is there any suggestions or is the TV faulty.
MONTY38RAY
TV
Hi change you sky box setting to 720p and turn motion off
it works ive done it
RAY
4 REPLIES 4
MONTY38RAY
TV
RAY
Vinnieac
TV
Thanks for the reply. I thought I had tried every feasible permutation with the settings. Obviously I missed this one. Working great and picture looks a lot better now. Cheers.
MONTY38RAY
TV
Glad to be of help Cheers RAY.
valleyboy22
Voyager
TV
why 720 when you have the 1080p option? I get this especially on my android tv box.
