Go to solution Solved
ITV X download help
(Topic created on: 08-01-2023 04:39 PM)
RobClaxton
TV
How can I install ITV X on a ue55es8000uxxu. Not a clue after trying this afternoon. Any help out there please?
3 Solutions
AndrewL
TV
@RobClaxton: Please be advised that ITV Hub (ITV X) is no longer available on Samsung Smart TVs released between 2011 - 2015, therefore it won't be possible to install it on your ES8000, which is a 2012 model. I apologise for any disappointment this may cause you.
leicesterMan
Troubleshooter
TV
Use a fire stick it's 100% better than using apps on Samsung tvs
JAMES4578
Samsung Maker ★
TV
Hi @RobClaxton  As your model is unfortunately not supported (as explained by @AndrewL )you would need to use an external connected Device.  see some information here https://support.itv.com/en_us/goodbye-itv-hub-hello-itvx
One Ui 5.0,Android 13 .
7 REPLIES 7
AndrewL
TV
leicesterMan
Troubleshooter
TV
JAMES4578
Samsung Maker ★
TV
RobClaxton
TV
Cheers!!
RobClaxton
TV
Will do, and thanks
RobClaxton
TV
Many thanks
markjletterk
TV
Thanks.  I was going round in circles with this problem too.
