Issue with UI on Menu
(Topic created on: 13-03-2023 09:17 AM)
JonBrewster
Whenever you try and access the menu on out Samsung TV (#UE43TU7100K) it overlays the screeen with random pixels. There is no way to use the menu, and frequently the screen will freeze and/or the TV will restart.
I've tried various suggestions from the internet
I've tried unplugging the TV leaving for 30 seconds and then restarting.
I've tried holding down the power button for 30 seconds both on the remote and on the television.
I've tried holding down the exit key to do a soft reset.
Nothing seems to make any difference. I'm coming to the opinion that this is a hardware issue, but I thought I'd ask if anyone has had a similar experience
4 REPLIES 4
TessM
Mastermind
Hi @JonBrewster ,
sorry to hear that you are having this issue with your TV. May I ask if this is affecting all the channels and sources? Would you be able to send us a picture of how the TV looks when that happens?
JonBrewster
Hi @TessM
So when the TV starts it displays the "SMART TV" text correctly, then it displays a quick burst of static before showing the TV picture.
If you try and access the menu UI this is what you get.
Thanks Jon
WhatsApp Image 2023-03-12 at 17.09.29.jpegWhatsApp Image 2023-03-12 at 17.07.09.jpeg
TessM
Mastermind
Is this only happening when you access the menu @JonBrewster ? Would you be able to record a video displaying the steps that you take to get there? Are all the TV cables connected firmly to the back?
JonBrewster
So, no cables connected to the back apart from the power
It's seems to be getting worse. Now it doesn't even display the Smart TV logo.
Thanks Jon
