Go to solution Solved
Is my TV bluetooth enabled ?
(Topic created on: 08/04/21 16:58)
geoffwba
TV
I have the Samsung QLED 2017 TV - model number QE49Q7FAMTXXU.    I thought it was bluetooth enabled as I have a Samsung smart remote.  However, the bluetooth option does not appear in the sound menu so it will not pair with a bluetooth receiver which is connected to my hi-fi system.  Do I need to purchase a bluetooth adaptor and how do I connect that to the Samsung Connect box ?
Pugs1957
Superuser I
Superuser I
TV
Are you accessing this through the settings menu, hitting sound on the remote only allows you to select what you have set up. Also, see https://www.samsung.com/us/support/answer/ANS00079347/
6 REPLIES 6
Pugs1957
Superuser I
Superuser I
TV
In the sound menu select speakers
geoffwba
TV
I've been there and there is no Blutooth option to enable me to pair.
Pugs1957
Superuser I
Superuser I
TV
geoffwba
TV
Many thanks -your solution works !  I think the problem may have been that the TV wasn't properly communicating with the Bluetooth receiver, which is a Justop BTR006.  I moved the receiver a bit nearer the TV and in line of sight and it then picked it up.  I don't know whether there is a better receiver available as I find I have to turn the hi-fi volume up quite high to get an acceptable sound, or maybe it is a limitation of the TV bluetooth output ?
Pugs1957
Superuser I
Superuser I
TV
I suspect its a limitation of the Bluetooth receiver from what I have been reading.
geoffwba
TV
Do you have any recommendations ?  There are so many on the market.
