Is my new 2019 UE43RU7100 compatible with smart remote and One Connect?
(Topic created on: 29-11-2019 08:22 PM)
Apprentice12001
Hi,
If my tv is compatible please can you tell me the the model numbers to buy.
Thank yo
1 REPLY 1
TessM
Mastermind
Hi @Apprentice12001 ,
the One Connect Box only comes with select TV models as it's not compatible with all the TV models. As the One Connect Box and/or the Smart Remote weren't included with your TV that means that they are not compatible.
Hope that this helps.
