Iptv doesn’t work on QLED
(Topic created on: 04-10-2019 07:29 PM)
SajoR
I have a Samsung QLED 55" QN55Q60RAKXZL I've tried several apps and ways to play IPTV on it and nothing has worked. I have 2 more LED UHD Samsung TV with the same apps and the same IPTV content and they work as expected. Does anyone know how to fix this?
4 REPLIES 4
AndrewL
@SajoR: As far as I am aware IPTV was removed from all 2018 TV models going forward. Apologies for any disappointment this may cause you.
Martin999
I just purchased my new Samsung qled and did not know that Samsung removes smart IPTV. I will not cry and be angry to Samsung but I just want to say, bye bye guys, so many years with you but my next tv will be LG and only because you wipe smart IPTV from App Store.
BennyCe
Yep, it's a shame that they have taken it off. I am using it via the Amazon Fire Stick.
Wish there was a way to side load the app on the TV.
elexido
Smart iptv is not my favorite, but you can install by usb in Tizen O.S. Its pretty simple getting the zip file. You need an usb fat32 to put the folder "userwidget" inside of zip file. Use google !
