Go to solution Solved
iPlayer keeps logging out
(Topic created on: 04-03-2020 07:28 PM)
RichardTaylor
Does anyone else have this issue. I have to log into it every day! Tv is
UE43RU7020
cheers
Rich
RichardTaylor
Issue solved.
i went to settings>broadcasting>HbbTV
turned OFF do not track
turned OFF private browsing.
Reloaded iplayer and my account was there!
8 REPLIES 8
AndrewL
@RichardTaylor: Please can you exit out of iPlayer and SmartHub, then go to Settings > Support > Software Update > Update Now, to check for any available updates. Have you tried signing in to iPlayer on another device to see if it remembers your details?
RichardTaylor
Thanks for getting in contact. Tv is on the latest firmware, iplayer has been re-installed. I am logged in on my Samsung tv upstairs and I've never been logged out.
I even created a new account to see if that worked, but I'm still being logged out.
RichardTaylor
Issue solved.
Members_4PlSbqO
This is the correct solution, thank you, to a very frustrating problem.
Vimes
Worked on my Samsung 43 frame
Members_4aaLMBo
Thank you
Lamber77
Also worked for me, cheers!
Gixxermick
This is what worked for me.
Settings
   >Broadcasting
      >Expert Settings
         >HbbTV Settings
            >Do Not Track - Off
I left private browsing on and works just the same.
It's a wise precaution to either delete your browsing history on a regular basis, keep it private or better still both.
Set Software update to automatic and you will never have to worry about that. It will just update it's-self as and when an update becomes available.
