Go to solution Solved
invisible connect cable to Samsung TV QE55Q95TATXXC
(Topic created on: 02/03/21 11:30)
hnt
TV
Hello
I want to buy a10m or 15m one connect cable to use between my QE55Q95TATXXC and my Samsung connect box which came with the TV. There was only a 5m connect cable included but need a longer connect cable. I can´t find out which model of cable I need. Anyone here who can help ?
hnt
TV
I have found out that it is VG-SOCR15, however Samsung has admitted that it doesn't work until a new firmware has been made.
5 REPLIES 5
antikythera
Back for More
TV
for what? network for smart functions or picture and sound from AV equipment?
hnt
TV
I need it to connect my TV to the One Connection box which came with the TV. There was only a 5m one invisible connect cable included but I need a longer one
antikythera
Back for More
TV
you mean this? https://www.samsung.com/us/televisions-home-theater/television-home-theater-accessories/televisions/...
there is a 10m one too but it's not that much cheaper
Tonys44
TV
But is this one compatible with the 2020 Samsung frame?
hnt
TV
