08-02-2019 07:19 PM in
TV
As you can see is sound level and Channel Number stuck on the screen. How do we remove it?
11-02-2019 08:16 PM in
TVHi @Cor32.
This shouldn't be the case. What's the full model code of your TV? Have you tried a reset? Go to Home > Settings > Support > Self Diagnosis > Reset. Note, any changes you have made to the TV's settings will revert back to the default settings.
12-03-2022 03:06 PM in
TV12-03-2022 03:13 PM in
TV24-04-2022 08:27 AM in
TVHi!
I have exact same problem. Model Ue43j5672su. Quite annoying problem to be honest. Tried running the TV setup again but that did not solve it.
24-04-2022 08:38 AM in
TVAlright, complete reset solved the problem!
