How to Screen Mirror from your Mobile Device to a TV
(Topic created on: 03-04-2020 06:52 PM)
AndrewL
1. The screen mirroring function on your mobile device will be called one of the following:
- Screen Mirroring
- Smart View
- Quick Connect
2. To find screen mirroring on your mobile or tablet, pull down the notification bar by swiping from the top of the screen to the bottom, then again to expand it, and select Screen Mirroring, Smart View or Quick Connect
3. Your phone or tablet will now search for available devices
4. Tap your TV to connect when it appears. If asked, enter the PIN that appears on screen.
5 REPLIES 5
ryukariotu
Voyager
it is very useful, thank you samsung for having this feature!!!
45exp
Does that only work for smartphones or tv.Or can it be used for normal tv has well.
harris_barris
Pioneer
Think this needs updating...
harris_barris
Pioneer
Na, needs a smart TV. If you have an xbox (or similar) you can download things like YouTube, Netflix etc...
snogger
So sorry 😞 😢 😐 Lovexxxxxx
