10-12-2019 05:36 PM
I want to sign on to use online streaming such as Netflix, Prine Amazon etc. but cannot work out how to do this onscreen. I understand there's a virtual keyboard, which may be the answer, but am unable to locate it. Any guidance please.
Thanks, Graham
Solved! Go to Solution.
10-12-2019 05:53 PM
10-12-2019 05:53 PM
10-12-2019 06:38 PM
Thank you so much, I was completely unable to find the answer in the manual etc. - worked perfectly.
Graham
10-12-2019 07:09 PM
