how do I connect my to my tv?
(Topic created on: 11-03-2021 06:52 PM)
Wazar
How do I connect my tv to my mobile
2 REPLIES 2
EllieSmith
bluetooth
AndrewL
@Wazar: If you have a Samsung phone and a compatible Smart TV connected to the same Wi-Fi network as your phone, then please swipe from the top of the screen to the bottom, then again to enlarge the Quick Panel, and select 'Smart View' from the series of on screen options. Select your TV from the list of available connections, enter a PIN if prompted and you should be good to go.
