Hotel mode
(Topic created on: 15-08-2024 01:52 PM)
Clifford84
Hi I took my tv off hotel mode now the screen is just black? What went wrong? How do I fix it?
2 REPLIES 2
Robin999
Samsung Members Star ★
Hi and welcome to the UK community
https://us.community.samsung.com/t5/Projectors-Other-TVs/Hospitality-mode-in-Crystal-UHD-TV/td-p/272...
You seem to have a tv designed for use in the hospitality sector.
JAMES4578
Samsung Members Star ★★
@Clifford84  Your Tv is indeed designed for hosptality,  usually there are only two options though,  Hotel Mode and Standalone.   There should be no issue with standalone as aware of other customers who have  used this Mode successfully.  you may  have pressed something inadvertently.
Firstly Can you try a soft Reset by holding the power on the Smart Remote for around 5 seconds until the Samsung logo appears. does this make any difference?
I f no success would disconect Tv for around 5 minutes to see if that makes any difference.  if not with Remote press  Mute 1,1,9  Enter.  if Menu appears see if you can select Network-Network Set up-(Tv Menu should appear)- select Network-Network Settings. Select desired Network type and proceed with set up.
