Help with Samsung 46inch TV....
(Topic created on: 24-04-2019 05:17 AM)
realdeal2414
My Samsung television started cutting itself off a while back. When I turn it back on it cuts itself off again after about 30 seconds. The Tv is out of warranty.
Model is UN46D4600UFXAZ
S/N is Z3453CAB800839T
any help would greatly appreciated!
2 REPLIES 2
SjorsK
Maestro
Ough, sorry to hear that the TV died, my first advice is to try an alternative power supply - If it works there something is wrong with the power supply you have there.
If it doesn't. I recommend to remove it from the power in general and call an authorized repair technician (Or order a new TV, depending on what you prefer).
You can also book a repair appointment with Samsung here:
https://www.samsung.com/uk/support/repair/tv-av/
realdeal2414
Thank you
