HELP! Samsung smart TV not picking up antenna
(Topic created on: 10-08-2021 07:11 PM)
Timi 10
TV
Hi all,
I'm having issues connecting my Samsung smart tv to a new tv antenna.
When I plug in the antenna to the tv and scan for channels, 0 channels are found. I also notice that there is no indication that the antenna is connected to the tv.
TV model - UE40NU7120
Antenna name - One for all amplified indoor aerial
I have unplugged the tv from the mains and also initiated a factory reset, neither of which have worked.
Would be grateful of anyone could help solve the issue!
2 REPLIES 2
Pugs1957
Superuser I
Superuser I
TV
Perhaps the antenna is slightly off which means you have a pretty impossible task. If the TV was tuned in you would have a chance of being able to position the antenna correctly but you have neither.
You will need a lot if luck and patience.
antikythera
Hotshot
TV
Might also be related to this if you live in the North East of England - https://www.bbc.co.uk/news/uk-england-tees-58169501
