01-06-2020 12:40 PM
Hi there. I have a Samsung QE65Q7FAM, currently fitted with a 15m near invisible one-connect cable. We are moving house and the TV will be a very short run away from the one-connect box, and also the cabling will be in the walls so there is no need for 15m or for it to be invisible. The TV came with the 5m near invisible able but I'm having trouble finding where we put that!
I've been looking at which cable would be a suitable replacement but there doesnt seem to be much info, does anyone know if either of the following one would be the correct cable:
There also seems to be non-HDMI versions, which I'm assuming are not suitable?
Thanks in advance for any help!
