Help me please for Samsung QE50Q60AAUXXU
(Topic created on: 03-08-2022 04:56 PM)
Hayden2
Need the default ADC/WB values and white balance settings from service menu accidentally pressed left instead of back hdmi calibration failed
tried all resets no luck
Is the font colour correct and the type correct?
What are the default values as these are the ones I adjusted myself. Please help
7 REPLIES 7
leicesterMan
Troubleshooter
To get default values all need to do is reset your TV, there should be an option on your menu to reset values back to original manufacturer mode
leicesterMan
Troubleshooter
Hayden2
I tried this but no luck but I really appreciate the help
Hayden2
Gonna give this a go but without remote and do it manually via tv
leicesterMan
Troubleshooter
If you have a Samsung TV, you can control it with your phone, use your phone as a tv remote, lots of apps on play store to turn your phone in to a remote control
leicesterMan
Troubleshooter
Try this, it's a virtual remote control gor Samsung TV
https://play.google.com/store/apps/details?id=ir.remote.smg.tv
Hayden2
Tried all resets with remote no luck and I really appreciate the help. If ya know anyone or can get the values can ya post them or message me.
