27-12-2018 10:58 AM in
TVI’ve just purchased a 49” Frame tv. I won’t be using the included wall mount as I have an extending Vogels bracket. It is a VESA standard an I know my new tv is compliant but I can’t find any instructions on fitting it. It looks like some sort of spacers are needed as the top mounts are set behind the bottom ones. Can you help?
27-12-2018 02:01 PM in
TVHello,
Normally, if you use your wall mount that respect the VESA 200 * 200 standard, you can use it for your FRAME without any problem.
02-08-2019 08:19 PM in
TVI have the same problem. Did you find the solution? If you did, please share! Thanks!
02-08-2019 08:42 PM in
TV09-11-2019 08:07 PM in
TVCan i ask what wall mount you guys used. I am looking for an articulating mount but I can't find one
09-11-2019 08:38 PM in
TVHi,
I used the Vogels thin 245 180degree mount.
We needed to get some alternative bolts to attach it to the TV but very pleased with it.
Vogel's Thin 245 180 Degrees... https://www.amazon.co.uk/dp/B009646V3G?ref=ppx_pop_mob_ap_share
09-11-2019 08:42 PM in
TVThank you so much! i thought the 2019 49 inch is 200 x 200? or is this one the max it will hold is 400 x 400 ? I am a newbie at this so just trying to figure it out?
09-11-2019 08:44 PM in
TVAlso, what did you mean by alternative bolts? I am going to do this myself. So i just want to know what i am getting into.
09-11-2019 10:24 PM in
TV11-11-2019 06:58 PM in
TVYou rock!
