Frame TV 32" 2020 - Art mode no mount
(Topic created on: 21-04-2021 09:30 PM)
Barleydave
TV
I have just purchased this TV and trying to load my own art but I do not want a border / mount (I want the image to fill the screen edge to edge).  I can find no way of switch off the mount.  I can select Modern or Shadow, but there is no option for None.
Having read various threads on here and blogs, I have tried various image sizes (1920x1080 72dpi), (3840x2160 72dpi) and (7200x4050 300 dpi). None of them offer me a No mount option.
This must be possible!!  Other threads with other models / years appear to have achieved it, but it's not happening for me.
5 REPLIES 5
Csky
TV
Do this:
Don't choose the passeportout in the app.
Just upload the image as is (indicated size) then there will be no passepartout. Choose passepartout and color of it in the TV if you would want that later on. Then save (middle button).
Good luck. Let me know. //CSky
HalC
TV
Hi Dave - i have the same problem, except sometimes the ‘no mount’ option is available and sometimes it isn’t. Frustrating. Did anyone else find out why?
Csky
TV
As I said earlier:
Klinghust
TV
In case someone is still struggling to get the pictures to be full screen (no borders/frame). Upload the picture as per @Cskys description. Make sure the picture is in 16:9 format before you upload.
To crop pictures:
Google Photos app > Edit > Crop > Frame icon > 16:9 > Adjust the crop > Save
Edit: the resolution needs to be exactly 16:9. I've found even the crop option fails at times. 16 divided by 9 makes 1.7. Make sure the resolution equals the same (i.e. 1920/1080=1.7 vs 1921/1080 does not equal 1.7 but rather 1.778...). Hope that makes sense and is helpful 🙂
Hayley7722
TV
I’m still having a mount appear even when I don’t select it. Images upload ed are all 16:9. ANy ideas?
