Flickering light and dark areas onscreen
(Topic created on: 30-03-2020 07:40 PM)
Johnnyivan
https://youtu.be/wyz3OH3_f8M
Hi all,
We have this horrible flickering on the right edge of the screen which has got worse over many months.
Video clip above.
It now looks like two triangular 'rays' of light against a darker area.
Is the screen on the way out? Or can it be fixed?
Many thanks :winking-face:
John
3 REPLIES 3
CarloL
Hotshot
Hey @Johnnyivan :smiling-face:
What is the model number of your TV? Try pressing the MENU button on the remote, is the Menu window clear or distorted in the same way?
Johnnyivan
Thanks for the reply Carol.
The model no. Is
UE32ES5500
In the menu, and when bluray is on, and when I do the picture test , there is no improvement.
John
CarloL
Hotshot
Okay! If the Picture Test didn't show any improvement then it may be worth having this looked at by a Samsung engineer. You can request to have one sent to you by getting in touch with your closest Samsung Support Centre, you can find your closest one here: https://www.samsung.com/uk/support/service-centre/
