Fix my tv
(Topic created on: 01-07-2022 11:18 PM)
Shbadbadobolacaca
How do I get my Samsung led tv to switch out of demo mode while I don’t have a remote
4 REPLIES 4
Devlin73
See if there is an app for the TV, you should be able to control the TV with it
Troubadour
Pioneer
Also Google tv model number and user manual as there is likely to be an answer there. Consider Googling the problem and see what turns up.
Bigtasty65
Troubleshooter
Have you looked on the back? It depends on what model TV you have of course. Just looked on the back of mine and I've noticed a (hard to spot) small joystick. Pressed it and it brings up the menu, with the moving of the joystick for navigation. Very clever but it is hard to spot unless you can turn your tv around and look for it.
Bigtasty65
Troubleshooter
Your model might have buttons along the top, bottom or sides of the TV instead. So give it a good check.
