24-03-2023 06:57 PM in
TV24-03-2023 07:01 PM in
TV24-03-2023 09:40 PM in
TVHi @R08 One of the things than cause reboots is outdated software,check you have the latest update. However a soft Reset by either holding in Power button on remote for 5 seconds or unplugging from the mains for a minute can sometimes fix issues. However can be due to faulty capacitors ,backlights or main board.
If the horizontal line is permament that would be a worry, advisable to check that there is no issue with the connections and reconnect. However if still troublesome would need to do a Picture Test. Go to Support-Self Diagnosis-Picture Test. if errors are displayed indicates crucial issue.
Would need to get in touch with Samsung Support regarding repair options.
One Ui 5.0,Android 13 .
25-03-2023 09:21 AM in
TV
