Extended Bluetooth-Range
(Topic created on: 27-11-2019 08:12 AM)
Freaked
Hi,
We´re using a UE65LS03NAUXZG (The Frame). Everything went fine, but now I tried to rearrange our TV-Wall.
As we are using the One-Connect-Box and the 5 meters One Invisible connection, I planned to place the One Connect at the Basement, so there is nothing else but the TV at this Wall.
Now, the remotecontrol doesn´t work as usual.
As it is Bluetooth, is there a possibility, to connect a USB-extension and place a Bluetoorh-Stick behind the TV?
Which model may work? Ist it possible to connect a bluetooth-stick to the One-Connect-Box and make it work?
Thanks for your help.
Daniel
0 REPLIES 0
