EVOLUTION KIT SEK2000
(Topic created on: 20-03-2020 08:35 PM)
FLYINGSCOTSMAN4472
Hallo everybody, hope someone can help me here. I have a UE46ES7090 with the latest firmware 2022. I have recently acquired a evolution kit sek2000 and have tried to install it.  Is recognised by the tv and starts the install process, it gets to 100% , then says no actual software found on usb stick. This is not right, I have installed the latest sek2000 firmware 1030 on the stick.
Do I need to downgrade the firmware on the tv, when yes how do you do this? Is there anyway of getting this up and running.
Many thanks for any helpful tipps
FLYINGSCOTSMAN4472
1 REPLY 1
AntS
Hi @FLYINGSCOTSMAN4472 , 🙂
Unsure if you sorted this already, but did you extract/doubleclick the .exe firmware file on the stick after downloading it?
