11-01-2021 07:25 PM
Can anyone tell me how to stop my 4K player from turning on every time i switch on my TV. If i continually turn the player off it eventually doesn't turn on but reverts back to annoying mode when I use it again. I have a Q90R tv and a Panasonic 4k player
Solved! Go to Solution.
12-01-2021 12:28 AM
11-01-2021 08:21 PM
11-01-2021 08:46 PM
Hi Pete I have the silver Samsung remote and the black Samsung that come with the TV and also the remote for the Panasonic
11-01-2021 11:18 PM
11-01-2021 11:30 PM
Unfortunately that’s not the answer although I’d like it to be that simple
12-01-2021 12:28 AM
19-01-2021 07:20 PM
Thanks that worked perfectly, not too sure why at the moment but I'll look into it later. I've connected the PS4 to HDMI2 and the Blu-ray to HDSMI4 just a swap over.
19-01-2021 07:32 PM
10-04-2022 11:58 PM
That does not work. I use HDMI 1 and my Panasonic DMP BD60 and it turns on with the Samsung
Q6F.
11-04-2022 12:12 AM
Yes that is how my Panasonic turns on. You can check this by getting about 4 inch wide sheet of tin foil. Fold it in half and hang over the front of your DVD PLAYER WERE THE DISC READ OUT LITES UP.
