Dolby Amos
(Topic created on: 26-11-2022 11:21 PM)
Bill010
Can anyone please advise if the Q990B sound bar will work with the QN94A 75" TV. I get that it will work with the TV in terms of Q-Symphony, but I want to understand if Dolby Atmos will work. Can't seem to get a clear answer, £1,299 is a lot to fork out if it doesn't actually deliver Atmos.
In anticipation, thank you.
AndrewL
@Bill010: If you connect the Q990B soundbar to your TV via HDMI (arc), then you can enable Dolby Atmos by heading to Home > Settings > Sound > Expert Settings > Dolby Atmos Compatibility > On.
3 REPLIES 3
LeoXXL
Pioneer
Do check your TV specifications in terms of audio what it does deliver as well as your sound bar, if one does not, then look elsewhere.
AndrewL
Bill010
Thanks for the response
